Dear sirs.
I am going to make downgrade from Vista to XP, but on FTP in a folder "downgrade" lay drivers and utilites ONLY for model TX5.
Whether they will approach for TX3?
Hi Gook,
According to the Specs (see HERE )the TX3XRP had XP pre-installed..
Is this correct.?
HiThalamus
Yes it is correct. I have made upgrade. It was not pleasant to me and now I wish to make downgrade.
Hi Gook
As long as the recovery partition has not been deleted, start your vaio and when you see the Vaio logo press the F10 repeatedly, this normally would start the recovery process and restore Windows XP and pre-installed applications..
