Drivers for an old Vaio ?
jimboy124
Hi , does anybody know where i can get the drivers for the following model it has two numbers on it
VGN 19VP and PCG7T1M
Any help would be greatful !!
rich912
Hi jimboy124,
Are you sure it is not a VGN-N19VP? Have a look on the screen surround.
If it is you will find the drivers here...
http://www.sony.co.uk/support/en/product/vgn-n19vp_b
Rich
Go n-éirí an bóthar leat
rich912
Hi jimboy124,
Rich
jimboy124
Rich, if i would like to send you a E pint !!
Cheers mate !!
Jim
rich912
You're welcome Jim :slight_smile:
