Hi , does anybody know where i can get the drivers for the following model it has two numbers on it
VGN 19VP and PCG7T1M
Any help would be greatful !!
Solved! Go to Solution.
Hi jimboy124,
Are you sure it is not a VGN-N19VP? Have a look on the screen surround.
If it is you will find the drivers here...
http://www.sony.co.uk/support/en/product/vgn-n19vp_b
Rich
Hi jimboy124,
Rich
Rich, if i would like to send you a E pint !!
Cheers mate !!
Jim
You're welcome Jim
