Dual Core XP Recognition
PNCosta
Hi.
I have a Vaio VGN-SZ1HP and Task Manager showed all two cores independently as it should. A few days later however, it has changed to only showing one graph for CPU usage. I know you can change the view to show the graph for each CPU but for some reason I only have the one graph per CPU option and it is greyed out. Are the two cores working correctly? How can I get my task manager back to showing all two cores again?
Thanks,
Pedro
0 REPLIES 0
