RAM Upgrade for VGN-SZ2M/B
yas9
hi!
i wanted to upgrade my notebook ram from 1gb --> 2gb
my notebook is a VGN-SZ2M/B
1. question: are there 2 modules built in (2x 512mb) or just 1 (1x 1gb)?
2. question: what exact type of ram do i need? (pins, ddr-type, latency, manufacturer)
thanks in advance!
tonybeard
Go to here and download their system scanner software to assess your reqirements. Its brilliant and you will save big bucks. My ram was £240 odd but only £83 with crucial and it was delivered within a couple of days. :smileygrin:
Thalamus.
Champion
Hi yas9
According to the specs your SZ2M uses DDR2 533mhz So-Dimm modules and that specs also state that your Vaio should have 2 x 512 Mb installed
Crucial as Tony Beard mentioned is a popular choice with Club Vaio members and another benefit from buying from Crucial is there memory compatibility guarantee. :wink:
Also you may find this guide, from Sony, on how to upgrade your Vaio's memory of interest.. :slight_smile:
