DVD-RW Verbatim illegible
giodan2007
Hi, I have a problem:
I have purchased 3 wrappings from 10 disks Verbatim DVD-RW 4x certified 4,7 GB/120 min SERL DVD-RW RW2 (reorder 43552).
I have tried to insert the disks in the DVD recorder of my desktop SONY VAIO PCV-RS302 but
the DVD recorder doesn't see them, because the computer asks me to insert a disk.
The installed model of DVD recorder in my computer is PIONEER DVD-RW DVR-106D 1.00
Can you help me?
Giorgio
sgiorgio@libero.it
5 REPLIES 5
rich912
Hi Giorgio and welcome to the foum.
Have you installed the firmware update for your optical drive from Vaio-Link ?
Go n-éirí an bóthar leat
giodan2007
Tanks for your answer.
In “http://www.vaio-link.com/downloads” I have seen that from “Available downloads for the PCV-RS302” there is “ Firmware Update for Pioneer DVR-106DVA but my optical drive is 106D and not 106DVA.
Can I downloads that firmware for recorder on Verbatim DVD-RW 4x or I'll can crash recorder?
Excuse me, but my english is terrible.
P.S. Can you speak Italian?
kee-lo_
Consiglio contro fare l'aggiornamento poichè è un azionamento differente.
Sperare che questo funzioni, esso sia una traduzione di Google :wink:
giodan2007
Can you repeat please your answer in english?
Your translate with google is not clear.
Do you think that the download that I have seen in web in “http://www.vaio-link.com/downloads” from “Available downloads for the PCV-RS302” is the right Firmware Update for my Pioneer DVR-106D (my optical drive is 106D and not 106DVA)?
Thanks.
kee-lo_
LOL trust Google :laughing:
I would advise against using the firmware as it's for a different drive.
