Hi guys. Is there anyway to avoid this entry screen displayed every time i turn my pc on? its very annoying to see this splash screen for so much time. Thanks
P.S. I have an FE11S if that makes any difference
did you have it as an old background? set the one you want to be your background as your background (for a second time), reboot, and it should do the deed :smileygrin:
I think he means this
oh right! i thought he meant the glimpse of your old wallpaper that i used to get on my desktop
Oooh right, well we can't read minds LOL
No you can't remove it, really annoys me too
I also have the FE11S, and asked Sony if it's possible to remove the annoying logo's wich display for about 10 seconds. The only thing you can get rid of the the splash screen with the sound in the beginning by going into your bios and change the settings.
It's part of the laptop, but very annoying indeed....
OH! where it goes VAIO before it asks for password? gives me chance to plug it in between pressing "on" and entering the password you can mute, but that's all
Hi JohnFish,
I have managed to stop the animation of the word Vaio in the start-up splash although sadly not the Vaio splash screen altogether but it does seem a little quicker.
Goto Start > All Programs > Vaio Control Center > Initial Setting and remove the tick from show animation, this also removes the sound as well.
yeah, but does it really matter? i mean, its probably preppin up or summat, and its not there for long. anyway, is this only with FS? i have an FS415E, and it does it o mine, althiugh i dont care
