Hi following my last thread about where to get memory from for the vgc-v2m, i was advised to go and check out Crucial. I found the memory i'm looking for and decided to buy a 1GB Ram, link below:
http://www.crucial.com/uk/store/mpartspecs.asp?mtbpoid=79A61228A5CA7304
Now i have a 512Ram installed, if i put a 1GB Ram in the other slot would my pc operate from the smallest RAM this being 512? Or will the sony combine the 2 rams together to give me 1512Ram (near enough)?
Should i just remove the 512 ram and install the 1gb?
Help please, any advise would be great.
Thank you in advance.
As your memory slots are not paired, you should be able to use both modules and have 1536 MB of available RAM.
