Hi guys. Is there anyway to avoid this entry screen displayed every time i turn my pc on? its very annoying to see this splash screen for so much time. Thanks
P.S. I have an FE11S if that makes any difference
Naturally you cannot remove this.. on any other PC you would get info on detected HDD etc, and that stays on there as long as the Sony logo does + it needs to give EVERY customer the time to enter the BIOS (not only the fast ones)... the animation+ sound is indeed something you can remove.
It p**ses me off on the RA104, as it would load in 22 secs if it wasn't for that!
ye, but it's checkin its got all its bits n bobs before it trys to start, in case it short circuits or damages itself, so if you (could) stop it, it may not do any good if there's any problems
Yeah ithink,, its there for a reason...
Do what I do....turn it on then go and do something else while it loads.
1)Boot your Vaio FE11S
2)When logo VAIO show, press F2 (to enter BIOS)
3)Look at the options and select "disabled" for logo startup
4)Press F10 to save&exit
It's all
that stops it movin. it still comes up
My VGN-FE11H takes 22-25 seconds to clear the logo and then as if mocking me, loads and boots up the windows XP with all the apps ready in 16 seconds. I had it sent to service but came back with a reply that it was normal for the series. Now, how can I be put to wait senselessly for 25 secs while any dumb laptop or pc boots up the BIOS in 3 seconds? This really really annoys me.:smileyangry:
