Hi
my english is not very good so sorry if i make mistakes.
I can't put some files in the playlist 1 after that i want to erase 1 file but i can't.
In the documentation it is written that i have to go in the playlist select the song (how can i do that ???) go to the advanced button (seems to be the button on the right) and click on the button with a x, i don't have this button anywhere ?
Someone can help me ?
Bon j'écris en français aussi, si personne ne me comprend 🙂
Je peux pas effacer de fichier dans la liste de distribution, dans la doc du vp ils disent de selectionner la chanson et de cliquer sur une icone avec une croix ? J'ai pas cette icone bizarro
Quelqu'un peut m'aider ?
merci
Amidamaru
hold down one of the 3 middle buttons correspnding to the track you want to delete. it's a bit hard to explain, you have to hold down the button for a few seconds to show the advanced menu. post back if you don't understand what i mean
I understand :smileygrin: it works, thank you very much.
Why could they not explain this in the documentation simply
And why the hell this function isn't for all the songs, i meen erase songs not only from playlist !
Or i don't see how to do it
