Whenever i start up windows xp home edtn i get error message from norton saying something like "please wait ...installing ."...and then second message "unable to use repair feature please re-instal" . the error i think is from norton security software. as it stops when i remove norton from the start up list of programs.
....is there any way of using norton and getting around this.
...possibly reinstalling norton may do it but not sure how to do this...... i can't see norton specifically by itself in the recovery DVD..... not sure where it is in stalled......
also can we access the hidden partision segment of the hard drive where al these programs are installed.... i'd like to put adobe on my desktop.
thanks for any assistence!
The Norton products on the VAIO only last 30 days, so uninstall it and download AVG from grisoft.com
SORRY NORTON EXPIRES IN 3 MONTHS IN TOTAL. its not expired yet. but since purchasing laptap i have had this error. norton works fine but the error msg is annoying as occurs whenever loading up windows. there 's a coreection to first psoting the first msg reads "preparing to instal" with norton 2005 in the header of the msg
anyone know how to extract the programs from the hidden partition
If you are still within the trial period I think that you can download the program from here.
You can always uninstall the norton antivirus via start-> control panel -> add/remove software
But if you want to install this back again, this has to be done via performing a full recovery.
Or following Rich's link.
