Even my Sony Vaio S can't handle an issue
maleahgates
Today my pdf file has stopped opening. I spent some days to create it and to add many valuable data. But when I click on the file to open it, nothing happens. I reinstalled my Adobe Acrobat to the ultimate version. But it didn't help. I don't know how to say on my job, what happened!
Brblacke
There is guide in the following, in case Adobe Tech Support can’t assist, then you would choose one of the ways below from search machine, who knows, what might aid you…
https://helpx.adobe.com/acrobat/kb/quick-fix-view-pdfs-web.html
https://helpx.adobe.com/acrobat/kb/troubleshoot-pdf-printing-acrobat-reader.html
https://onlinefilerepair.com/en/pdf-repair-online.html
  1. Right click on any PDF document -> Get Info
  2. Click on Open with entry on the get info dialog
  3. In the Application dropdown locate to your installed copy of Acrobat and select Acrobat application
  4. Once you have selected Acrobat click the "Change All button below the drop down"
  5. Click Continue on the user confirmation dialog
  6. Quit the Get Info window
EdwinaU
Moderator
Hi Maleah,
Welcome to the community.
This sounds like a .pdf software issue. We would recommend you try Acrobat for advice about this.
Thanks,
Ed
Brblacke
