FE21M Sound Problem HELP!!!!
steelem
the sound on my fe21m is awfully low on the highest volume - i have adjusted the vol in bios to max & ok yes it increased the sound but its still not good enough - vlc media player seems to increase wattage but still not brilliant - I am asking now if you guys have any ideas
sigma tel audio is the default sound device is this correct?
rich912
Hi steelem,
Have you seen this thread?
Edit: Sorry, ignore this post - I have just noticed that you have contributed to that thread...
Go n-éirí an bóthar leat
