FE31H screen loose...
Baka06
im not sure if this is just me or not but my screen seems 2 be very loose and when closed down the screens on a angle on the left side, is this something i need 2 get sorted or is it the same with all fe31h's?
kee-lo_
Yes I think you should contact VAIO-Link in the morning as it's not right
Baka06
ok cheers, i dont spose you have a number handy that i can ring them on?
Thalamus.
Champion
Hi Bakao6,
As Vaio-Link appears to still be unavailable, I have found this number which I think is still correct..
United Kingdom0870 240 2408
Edit sites working again now, see contact details here
