Fimware Update for Matsushita UJ-841
ErichSilva
I posted a question to VAIO support, but haven't received an answer. Here is the question I posted:
Fimware Update for Matsushita UJ-841 is correctly updated but message still shows:
"Update programs which have been already downloaded. Finish the intallation by following the Installation Instructions shown when clicking the program name."
Really annoying because I want to have the "VAIO update notification" running in the system tray if an update becomes available, but now I have to turn it off becaue of the Firmware update notification error...
Does anyone know how to resolve this issue besides turning the notifyer off?
TIA- Erich-
11 REPLIES 11
Thalamus.
Champion
Hi Erich,
Welcome to Club Vaio
If you let me know what vaio model you have & the update link, I'll forward this on for you.. :slight_smile:
ErichSilva
Hi Thalamus,
Thanks.
I have the VGN-FS495VP series.
I appreciate it-
Cheers,
Erich
ErichSilva
I forgot the update link... It is:
http://www.vaio-link.com/vu/vu21/vu21.asp?l=en
Thanks again,
Erich
Thalamus.
Champion
I've forwarded the problem on for you Erich, hopefully it will be sorted soon.. :slight_smile:
ErichSilva
Thanks alot.
I like when things work properly as I'm sure you do too.
Cheers for now,
Erich
Thalamus.
Champion
You're welcome.. :slight_smile:
robpaxton
The last time this problem came up it was caused by the update procedure not being precisely followed. I seem to remember that it was caused by not opening & closing the drive tray at the right times . .
It may be worthwhile trying the whole update again making sure that the drive tray procedure is carefully followed. HTH..
ErichSilva
Thanks Rob,
I definatally had the drive open like I should. This is the second VAIO I've had as well. So I have done this process before.
Thanks anyway,
Cheers,
Erich
profile.country.BE.title
SonySQE
Community Team
This should be solved now.
Could you please confirm?
