after a joystick software installation, that it included a new keyboard driver also, the keyboard on my Vaio PCG-K115Z doesn�t work well just so.
When windows XP is going up I heard some bleep and if I open a notepad it automatically filled with key 2, I stop it with some Enter, but from this moment key 2 never work.
I�ve already performed a factory recovery but nothing is changed, the last opportunity is to change the bios.
Is there someone that can send me the original bios of my Vaio, if you have performed a bios update the original bios is a file named *.bak in C:\Program Files\Phoenix Technologies Ltd\WinPhlash .
I�ve tried a re-write of the bios but WinPhlash check the version and it prevent me to do it because are the same.
