firewall
zina
firewall
every time i turn on my laptop my firewall is down and i have to turn it back on.
ap untill a month ago it was on all the time i only turned it of manualy when i wanted to....
how do i make it be permantly on like before without having to do it manualy?
23 REPLIES 23
rich912
Zina,
The firewall not automatically enabling at boot can be symptomatic of a virus/trojan on your system.
Let¿s hope that isn¿t the case, but which firewall are you using and the version?
If you are using Norton then in Options > Auto Protect you will shoud find a check box for "Start auto protect when windows srarts up"
Go n-éirí an bóthar leat
profile.country.de_DE.title
seb21__
:thinking: you could add the firewall into the autostart.
Lizzie
how do you do that? i want the program that allows you to remove hardware safely loaded in my taskbar and to stay there.
Hope you don't mind me borrowing your thread Zina. :slight_smile:
seb21__
LOL
    Start > All Programs
    doubleclick on "Autostart"
    rightclick in the window
    new > link
now search the .exe file which starts your firewall and click ok
Lizzie
LOL
    new > link
thanks. but hmm i don't have autostart, do you mean startup?
seb21__
LOL, of course. That's it.
German Windows is a bit different.:smileyblush:
Lizzie
no problem :smileygrin:
rich912
Lizzie,
The safely remove hardware icon should be there in the system tray by default. There is nothing in the start options or services tab of msconfig that covers this.
However Windows has a glitch, insomuch as although these processes are running they occasionally fail to appear.
One workaround, if it is not visible in the tray, is to log off and then log on again ¿ not very convenient but it usually works.
zina
i had norton but the subscription has finished you think its becuase of that?
but it still works when i TURN THE FIREWALL ON MANUALy.
i thougt firewall was from windows
