firewall
zina
firewall
every time i turn on my laptop my firewall is down and i have to turn it back on.
ap untill a month ago it was on all the time i only turned it of manualy when i wanted to....
how do i make it be permantly on like before without having to do it manualy?
23 REPLIES 23
zina
no haven't uninstalled norton yet and not downloaded the antivirus you recomended
tell you if the problem is sorted when i do these 2 things
thanks
rich912
Zina,
Re: firewall
Sygate is a firewall - I thought that was what we were talking about.
You can use multiple anti virus programmes but only one firewall, otherwise you will get conflicts.
Go n-éirí an bóthar leat
zina
aha......
ok ,got it now!
but is it normal that its still on my trray and that it scans?(norton)
rich912
Yes, that is normal, but you can no longer update your definitions :slight_frown: - that is a major problem as new viruses appear every day.
