FJ1S turns CPU to max speed when it wakes up
pneves
Hello to you all!
I have an FJ1S and I can place it in standby or hibernate without problems.
The problem is that when the computer resumes, no mater the power management scheme, it always wakes up at maximum CPU speed. Moreover, the Computer properties says its running at 799MHz, but the fan keeps running from time to time and the computer runs much faster, indicating a superior CPU speed.
It only happens after standby or hibernate. I do not change power supply between operations.
Anybody has any idea on this???
Thanks in advance,
Paulo Neves
0 REPLIES 0
