FOLDER ISSUE VITH VISTA
babalexa
Hi all
I own a sony vaio vgn fz 21m with vista home premium 32 bit
The issue i face is every time i open a folder and then another one the previous one is closed automatically even if i check the option "open folder in its own window"
It is very annoying and i cant find any solution
Please help
babalexa
I have solved the problem
Thalamus.
Champion
:cool: Glad you've solved your problem babalek.. :slight_smile:
