Recovery Disk - Runtime Error
nonexclusive
Hi, I just bought the VGN-FZ21S running Vista and I'm trying to create the recovery discs for safe keeping.
However when I press 'Start' button under Create Recovery Discs the following error appears:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\Sony\Vaio Recovery\Launcher.exe
This application has requested the Runtime to terminate it in an
unusual way.
Does anyone know how I can fix this problem?
7 REPLIES 7
Thalamus.
Champion
Hi nonexclusive,
welcome to Club Vaio.. :slight_smile:
Have you installed the VAIO Recovery Center Patch 1.1.4.7.?
If not you can download the patch using the following link: VAIO Recovery Center Patch
nonexclusive
Thanx,
Yes I have installed it - the problem is still there
Thalamus.
Champion
Hmm the fix has solved this problem before.. :thinking:
Have you tried a different DVD manfacturer, ie Verbatim or TDK DVD+R.?
nonexclusive
The error occurs before any disc is inserted
DJVorny
i have got the exact same problem here it wont let me do it at all :cry: i made a email to sony support over a week ago and still no reply . it sucks becouse this is a brand new laptop all i want to do is make a backup and i am using it for my personal stuff and do not want to loose all my files ect :slight_smile: if anyone has a solution i would be happy to hear becouse after doing some searching it seems like this is a big problem with alot of other people also on a google search there is alot of threads on different forums about this :cry:
DJVorny
it seems i may have found the problem after looking in some threads here before i made my own one about the problem to see if this had come up before and i found this here http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=46647&lastpage=yes seems like my problem was deamon tools not sure u use that but if u do try and uninstall it and try the recovery disk again :wink:
nonexclusive
I didn't have daemontools but another virtual dvd drive and that's what caused the problem.
ThanX!!!!!
