I have formated my laptop Vaio FS212S.
It had preinstalled windows xp home so i have formated it and now installed xp professional.
I have installed the FS utility pack but when i try to run vaio update from "Go to vaio web support" to check the available updates I find an error page "http://www.vaio-link.com/vu/index.asp?l=en" with the message "The page cannot be displayed".
What i have to do to ? Why it doesn't work?
I assume that you mean FS215S. If so go to Vaio-Link and download the Help and Support Center Update. This should solve the problem. Otherwise just download any updates that you require from that page.
