starting the computer
odoardi
WHO CAN HELP ME?
1. Installed service pack: WindowsXP Home SP2
Still using service pack: yes
2. Detailed problem description: I still have a problem when i turn on the computer (in orde to solve it i sent it to the warranty service but it seems like if the problem is still there). The problem is that almost all the time i want to start the computer it appears the vaio logo and after it a black screen having on the top of the left side of the screen a little white line flashing all the time and the computer doesn't start. In order to start it i need to press the ctrl+alt+cancel many times. Now i am thinking to send it back to the warranty service but before i do it again maybe you have a solution for it. Anyway i have the feeling the computer i have is a real bad machine. In the reparation they changed everything, motherboard, harddisk, etc. etc. and the problem is still there.
3. Checked for upgrades or patches: yes
rich912
Double posting only causes confusion. Please refer to your original post.
Go n-éirí an bóthar leat
odoardi
i tried with pressing f but still the same problem
rich912
In that case return it and have them carry out a further repair. This, unfortunately, is not the first time that PC's have been returned with the same fault:smileysad:
