FS115B + CD/DVD Burning Software?
Longhair
I am using Win 2K and I need to know what software I can use to burn cd/dvd's with.
I tried downloading "Click to DVD", but no matter what version I get, it is an upgrade and it won't install.
10 REPLIES 10
Thalamus.
Champion
Hi Longhair,
Nero would by choice for burning CD/DVD's, this should be available from most software retailers.. :slight_smile:
Longhair
Nero doesn't work.
I tried it and it doesn't even show the cd/dvd drive as a recordable device.
kee-lo_
I think they stopped supporting Win2k after V5
Thalamus.
Champion
I've checked a few sites and they all seem to state the Nero 7 Premium supports Windows 2000 / XP / 98 and Nero 7 Premium Reloaded requires Windows Windows 2000 SP4 onwards... :thinking:
Amazon do have the older version available, see here for details.. :slight_smile:
kee-lo_
Maybe you just need to install SP4 then Longhair?
Thalamus.
Champion
Hopefully it will be that simple.. :slight_smile:
kee-lo_
Time will tell
Longhair
Sorry for the long delay in replying...
Anyways, Win 2K SP4 is installed and is pretty much required for everything, so that is not the problem.
Thalamus.
Champion
Hi Longhair
I'm still sure that you can purchase versions of Nero that are compatible with Win 2000...
But failing that you could try a free burner something like Amazing CD & DVD Burner, not sure what it's like though.. :thinking:
