Hello !
Is thery any program available to set the fan speed manually?
Kind Regards
Stephan
Yes, Google "Speedfan" and you can control the speed of all fans.
Note: the fan needs to be connected to the motherboard and not just the power for control.
(With a laptop that's not a problem)
