Hi
My left arrow key has stopped working on my keyboard. I removed the key to check and clean, but still no luck. Can anyone offer advice? If there is no way to try and fix it, could replacing the keyboard do the trick? It's an old laptop, but it's still ticking over, although I'm not sure I would be able to find a new keyboard for this 'old' model.
Any suggestions or advice are much appreciated.
TIA
