can I use my sony CPF-IX001 to listen music from my sony ericsson walkmann phone
is there any adaptar avilable to use it like that!
Please help me
Welcome to ClubVAIO
The speaker system you descibe is contolled on a network basis. This means that it is connected by a wireless connection which your Sony-Ericsson phone does not have. I don't believe that there are any adaptors available for this but if you wish to listen to music from your phone on speakers my i suggest these .
Hi alapati and welcome.
I believe your CPF-IX001 speakers do have an analogue Audio IN plug in addition to the wireless connection. This is just a stereo mini-jack plug.
Check this is the case - if it is then you will need THIS MMC-70 CABLE
I think this cable should work
Thanks Mr Blencogo
