Hibernation
leethepee
Hibernation
Hi, I have lost the ability to hibernate my laptop. I am unsure as to why this is becuase I did have this when I purchase the laptop however I turned this function off.
Any ideas of how I can enable this function again?
5 REPLIES 5
Thalamus.
Champion
Hi leethepee
What model Vaio do you have and are you running Vista or XP?
leethepee
running vista. i have fz18m laptop.
it al happened after I did a disc clean up. I think I may have deleted the hibernation files within this option
Thalamus.
Champion
Hi leethepee,
Yes running a disc clean up can remove the hibernation file and turn off hibernation..
This LINK should provide you with a solution.. :slight_smile:
leethepee
Works a charm mate. Thanks!!
Thalamus.
Champion
:cool: You're welcome.. :slight_smile:
