Hi!
I see sometimes an horizontal black lines shadow in my new vaio T2XP.
I don't know if it is normal cause I saw it too in another one in a shop, but I don't see it in other models.
It seems maybe has a low refresh rate or something like that...
Any one feel this problem?
The 59Hz jimbo will be really interesing because if youre t2xp works fine and say 60 hz instead of 59 i can tell it to vaio link and they will have to repair my t2xp also!!!
thanks for all jimbo!
jimbo plis can you check the fact of 59hz???
other web that shows the problem is www.xbox-scene.com
