HOW CAN I PROGRAM THE S BUTTONS WITH SCREENSAVER?
Arhuna
Hi every one. Excuse me because i'm not used to write in english.
I want to know how can i program de "S" buttons with de screen saver or the <<turn off monitor>> options whithout installing any strange software.
I've seen the chance of programing the "S" button with the option "begin aplication". What you think is de best route for do this with XP Home Edition software?
Thank's & greetings from Barcelona
:slight_smile:
Thalamus.
Champion
Hi Arhuna,
Welcome to Club Vaio, :slight_smile:
Goto Start > All programs > Vaio Control Center (may have a slightly different name) and click on S Button..
A new window (S Button) should open, select the Launch Application from either the S1 or S2 drop down list, then click on the Advanced button in the settings section next to the S button you have chosen..
In the Specify Application box click on browse button (....) box and browse to C: > Windows > System32, then scroll to whichever screen saver (something.scr) you wish to launch and select it. Then click open and then click OK on the Specify Application window, then finally Apply and OK on the S button window..
Close all the windows down and test.. :slight_smile:
