How do I fit a Printer to a VA10 fit 14E.
Hello everyone.I have a Sony personal computerVA10 fit 14E.How do I fit a Printer to this unit
rich912
Hi tomlynmunt,
What type of printer are you looking to install?
Depending on which particular model Vaio Fit you have there should be the following connection options available to you.
• USB
• Wireless LAN
• Bluetooth
• Ethernet
Rich
Go n-éirí an bóthar leat
How old is the printer? Old enought to have an LP1 socket? If so... you can get adapters to change it to USB.
