How do I install Bluetooth
GaryBolton
I have re-formated my laptop and put XP Pro on instead, but it seems I dont have Bluetooth installed. How do I install bluetooth on my laptop
11 REPLIES 11
feederfan
Do you have inbuilt bluetooth? If so the drivers will be on VAIO-Link somewhere. Otherwise a USB Bluetooth dongle is only about £25 off ebay :smileygrin:
kee-lo_
Install SP2 and you'll not need more software or drivers
Michel75
That did not work with my 3Com Bluetooth PC Card. Does that mean it is not supported?
kee-lo_
No, 3Com probably have an updated driver on their website.
GaryBolton
I have just reformated my VGN-A215M laptop, installed XP Pro and downloaded and installed SP2. The problem is after installing on the drivers and getting it working pefect. I have no BLUETOOTH driver installed, can somebody please post a link to the correct Bluetooth driver I need to download, and also tell me if I also need "Bluespace NE" installed also to work with the driver.
GaryBolton
I need some help here guys, I have done a clean installation of Windows XP and installed SP2. But I see nothing in the control panel that has anything to do with bluetooth after installing SP2
I'm using a VGN A215M Vaio laptop. Can somebody please tell me what I need to do to get the bluetooth working and if I need to download anything from here like a driver etc. If I do please post a link ti the correct file or files in question I need.
mvanwambeke
check here for the specs of the laptop, there is no bluetooth on this computer for as far as I can s...
So if you purcase, like suggested, a dongle or PCMCIA card this should be autodetected
GaryBolton
Well it did come woth bluetooth software installed as factory default, so I'm not sure. I was under the impression it came with it.
So if my laptop does not have bluetooth, why does it come with the software installed as factory default.
kee-lo_
Doesn't seem logical does it?
