Apart from pushing the switch that is!
I want to be able to turn Bluetooth on and off but keep my WIFI net active.
Hi Meld51
From your on-line user manual:
Select both Bluetooth and wireless LAN.
Just keep in mind that using both 2.4 Ghz WLAN and Bluetooth simultaneously can result in system instability. My advice would be to use only the 5 Ghz WLAN simultaneously with the Bluetooth device.
