Hi all, hope you are all enjoying your Vaios. I am interested to know how long a laptop can be left running. I also wonder if laptops have a run-in period. Who knows please?
Just curious.
Regards
Shen
Shenyap,
As far as I know a laptop can be left on as long as you like (we have some at work that have been on for years... ...literally!). However, the longevity of laptops seems to vary widley. I thing some of it is just luck, some keep going for years, no problem! :smileygrin:
Others fail within a few months!
As for running-in, noooooo, just go for it!
CW
I use my laptop as a desktop replacement which means I sometimes leave it on for days to download things.
I am on my second laptop, the first one needed to replace because I cracked the screen and not because it "died" on me.
So you can leave your laptop on with out worring to much.
A laptop left running on a desk is likely to last longer than one that is frequently opened and shut, disconnected, put in a bag, carried around, etc.., with one possible exception - the fan may wear out sooner.
Laptops used as portable machines tend to develop problems such as internal connections working loose, hinge fatigue and loose or broken sockets.
Given that a laptop consumes 10% to 20% of the electricity of a typical desktop computer, it may well prove to be cheaper overall than a desktop when purchase and running costs are combined, for situations where the equipment is left running for long periods.
John
John raises some good points!
I have noticed on many occasions when performing internal cleans or upgrades on laptops that frequently screws are either very loose, or simply missing!
I am sure, as John states this is to do with their constant opening and closing and general movement! A bit of a bummer for a mobile computer.
Dell laptops used to be particlarly bad (there better now)! One we had a work got a screw jammed in the cooling fan and the screen would suddenly slam shut whilst you were typing (it did amazingly still work though)!. I am afraid to say the VAIOs are only slightly better!
CW
The only real restriction on leaving a laptop on is the risk of overheating. I leave mine on a lot, but I check the temperature every so often to make sure I'm not knackering my computer. It knackered anyway, but nevermind.
Anyway this program will help you keep an eye on the temperature if you are worried. The most important one is the CPU, which should absolutely not pass 75 on a laptop.
John is right, moving it around probably causes most of the problems, accidental hits in the car, on the bus etc have effects.
I wouldn't leave mine on > 12hrs.
Yeah that's a little high. I was refused permission to look at this thread (?) because it insisted I wasn't logged in, but if I remember there's a bit about cleaning out your vents in Nick Pans Cooling Guide
Yep a clean out is probably required
