Hi all, hope you are all enjoying your Vaios. I am interested to know how long a laptop can be left running. I also wonder if laptops have a run-in period. Who knows please?
Just curious.
Regards
Shen
:smileynerd: Yup gonna clean it tonight. Thanks for the link TygerTyger will post the results soon as.Cheers
Pjay
Pjay
Actually it's Bad a$$ M f***king Jay !
Hehe
I think that show has gone down the banks but the first two seasons were good.
eeehee im stuck on base 1 at the mo..... just 5 mins back I shut it down removed battery what a stinker of a port cover that is on the GRT795MP bet load of them get broken..anyway I looks for the screws that remove the keyboard n top pannels and can I f**k find em :smileythinking:. so I just rebooted to look at the manual, Little Britains my fave at the mo
**EDIT** Well I looked but I kinda knew I wouldnt find the answer in the manual.
I have removed every screw n clip I can find but the thing still wont come apart I just cant figure it out
No chance of finding info on this site without trawling thru s**t loads of pages.its so crazy I say CRAZY that we still dont have a SEARCH FACILITY HERE.
Pjay
Got it sorted ...now its clean I got a right lump of fluff from the back of the vents it actually looked like a filter screen and was about 5mm thick , the wife said "isnt that supposed to be there it looks like it should". my temps down to 55 instead of 79 with loads off apps running. oh yeah and its as quiet as a mouse. Im really chuffed. thanks guys..........`Bo selecta'
Pjay
That's proper Bo!
You're a bad cleaning VAIO using mother
sha mon Keelo ....:smileydancing: can u tell me how to upload a pic please
Pjay
Shamon brother.
Do you have webspace? If not use http://www.hostmyimages.net/
Then you do
without spaces.
Cheers Keelo i put it on my webspace ......wanna have a look at me fluff
http://homepage.ntlworld.com/michelle.coffey5/PCG-GRT795MP.html
Pjay
