How to change Video Card
nightflier
Hi everyone !
I'm new, i bought my Sony Vaio VGC-V2S by few weeks, i would like to change my video card, and replace it with a most powerful one. How can i do it ?
Thank you all :wink:
5 REPLIES 5
babysmile
nightflier,
I think VGC-V2S have quite impressive Graphics Card already.. but unlucky U cannot change any new Graphics card to this system. This is because it is design as a hybrid PC-TV system...
Unless some third company has released a USB connection for graphics card ( which till my knowledge is no way yet at the moment. )
nightflier
thank you for the answer,
the graphic card of V2S is a GeForce Fxgo5700 128Mb, I would like to replace it with a new one, but if it's impossible.... :slight_frown:
thanks anyway:smileyhappy:
BartK
indeed it is.
V, W and M series are impossible to upgrade (except memory that is)
Josh-2552
surely you should be able to upgrade anything on a desktop!?!? that's a bit annoying. i can on mine, although it was built from scratch- is it common that you cant upgrade desktops completely.
BartK
I agree, but you can hardly say that the V, M and W series are normal desktops. They are an all in one solution, therefor making it difficult to add any components...
