How to clean my X-BLACK LCD ???
rafaell
How can I clean my X -BLACK LCD ???
I found that I can use only a soft, dry cloth to wipe the LCD, but it's not enought to clean it.
Can I use anything else ??:smileyconfused:
rich912
Try a microfiber cleaning cloth moistened with a small amount of water - works a treat on mine.
Go n-éirí an bóthar leat
Domenico3go
My solution are the same a microfiber cloth. The Scotch Brite - 3M is good i think.
kee-lo_
I got mine from Aldi, it's superb
