How to copy hard drive to other hard drive
Philippoussis
is there a way that you can out all the information from one hard drive to another one without installing everything again,
i heard something like northon ghost or something but how does it work and what does it do?..
or is the only way to install everything again..
7 REPLIES 7
kee-lo_
Yes, it's called Acronis TrueImage
Philippoussis
thank you i have the program now...
i installed it but if i make an image of my computer do i save it on a usb/cd-rom and then i put my new laptop in the notebook i install windows on it and then i inset the usb/cd-rom and then all the settings and program's and all the stuff are the same like i had on my old hard drive?...
kee-lo_
If you have an external hard disk I would use that
Philippoussis
if i put in my new hard drive..
do i keep my VAIO Zone,VAIO Media etc. and the bar on the right of my screen the quick bar from sony(the nice blue one) and if i don't have this when i installed windows on the new hard drive is there a way to put all the sony software back on the new drive?..
RyanNicon
google G4U that what we use
Philippoussis
hi, thnx for all the help
but the hitachi-travelstar-7k100 has as interface ata-6
and my laptop has sata,
can i buy this hard drive or won't it fit..
if this drive does not fit(i know they are both 2.5 inch so it should fit no?)
if it does not fit can somebody maybe give me another site with a 7200 rpm drive that is really good comparable to this one
thank you
kee-lo_
No, you need a SATA 2.5" drive like this one
