HOW TO EXPAND MY RAM FROM 1024MB TO 2048 MB ON MY VGN-N11S/W?
phoenix3123
can any one suggest me how to expand my RAM on my vaio VGN-N11S/W model to 2048 and how much does it cost me? it will be of great help. thanks in advace :slight_frown:
Thalamus.
Champion
Hi raavi
According to the specs your N11S/W uses DDR2 533mhz So-Dimm modules
Have a look at Cruical.com your model is not listed but hopefully if you use there system scanner crucial should suggest the correct RAM for your Vaio, I think you'll find a 2GB kit should cost around £31.71 inc. VAT, several members have bought extra RAM from crucial and another benefit from buying from Crucial is there memory compatibility guarantee. :wink:
Also you may find this guide, from Sony, on how to upgrade your Vaio's memory of interest.. :slight_smile:
