how to get the original software installed on my vgn-fe31m
topepits
last 3 feb 2007 just purchase my new sony vaio vgn-fe31m. Unluckily i formatted it to windows xp professional service pack 2, all drivers installed and working but when i used my s-video to watch tv on my vaio not working. Just want to know where i can get the cd for the origianl software installed like sonic stage,dvgate,windvd,roxio digitalmedia,etc. because when i go to the retailler PC World they told me they cannot provide me and the cd is not included when i purchase the vaio they advise me to contact you instead.
Thalamus.
Champion
Hi topepits,
Welcome to Club vaio, :slight_smile:
Before you installed Windows XP pro did you use the Sony Recovery Utility to create a recovery disc set..?
If not then unfortunately you are unable to download the pre-installed applications but, if you want to and your recovery partition is still intact, you can press F10 repeatedly when starting your Vaio, to restore your Vaio back to it's original factory settings, ie Sony installed Windows XP and applications..
