Hi I have Vaio VGN-FE28B and I can't make bluetooth work properly Actually I can't even turn it on. When I turn on the bluetooth utility it shows me that bluetooth radio is turned off I didn't change anything in bluetooth settings since I bought it Can anyone help me? Thx
Hi sory only russian or deusch language
What do you mean? If You can't speak english why post a reply in this thread??
I dont think the FE-Series models ending in B or H have a bluetooth capability included. The M, S and Z models do have bluetooth.
Check your specifications carefully as I am only fairly sure of this.
Bluetooth, even when you have the facility, isn't that easy to setup. When my step father got his new phone it wouldn't pair, and it took me ages to get it to understand. Finally got it to work, but 30mins is a bit of a PITA
I guess You are right guys Bluetooth is not stated in my comp's specification The thing is software for bluetooth was on my comp from the very beginning and I can see it in device manager That's why I was confused.
i have a fe21h vaio and it does have bluetooth
how i enable it, is by right clicking the wlan device switch on the task bar
