If you have upgraded to Vista,
Rich77
If you have upgraded to Vista, I want to ask?
Does your Sony software work? click to DVD and sonicstage.
and
can you still use the remote control to launch and operate meddia centre?
i know you have to get new drivers.
phoenix198
Just (this evening) upgraded to Vista on my VGC-RC102. Compatibility as follows:
1. Click2DVD - No
2. DVGate - No
3. SonicStage - Yes, with the SonicStage Upgrade Program Version 4.3.01.14050 downloadable from the Vista updates area. That said, I don't use it.
4. Don't use the Sony Remote Commander, so not sure if that is compatible. However if you have a remote that works with Windows Media Centre 2005 then it should work with Vista.
5. Norton internet security is NOT compatible with Vista and must be uninstalled before you try to upgrade to Vista
Also, couldn't find a compaible driver for the installed Analogue TV card, so I swapped it out for a spare Hauppage DVB-T card I have.
One anomaly:
The VAIO Update Version 3.0.00.13220 programme downloaded from the Vista Updates area is incmpatible with Vista!!
