IIS is not working!!!
ASP_Master
Hello,
I need serius help. I have got an VNG-FE31M with WinXP MCE preinstalled. Now I need to code some scripts in ASP, but this does not work, because the IIS (Internet Information Service) is not working! All I get is an error. I have reinstalled the OS a few times from the recovery disks, always the same thing. But:
I have another copy of Win XP Pro, and there IIS works fine. So it is not a hardware issue.
Windows XP MCE is a modified version of Win XP Pro, so IIS MUST work somehow. I tried everything, it does not work. I can not install the another version, because then not all drivers can be installed from the recovery CD (thank You for making it this complicated, Sony).
Well, I need help on this one, I am thankfull for every post.
Cheers,
Branko
4 REPLIES 4
Giovanni26
Can you tell me wich error?
Giovanni
ASP_Master
It says "Server Application Error". This can mean evertything. Even when I install IIS from my own XP Pro CD it does not do anything. Maybe the whole OS is not okay, wich would mean that it is not delivered correctly.
Giovanni26
I cant help you... I have succesfuly install iis on media center and all works!!
Sorry
Giovanni
kee-lo_
Hi
ISS doesn't work too well with MCE, which is bizare as it's Pro + Media Centre.
Have you tried the Microsoft newsgroups? A lot of ASP experts in there who would know a lot better than me (I'm more a PHP user)
