Hi all, i'v got a vgc-v2m and yesterday i had a trojen virus on my pc, cleared it all up as norton picked it up, but noticed today that every time i reboot my pc i get an error on the start up saying:
CAUTION
you are attempting to open a file of type 'ActiveX Control' (.OCX)
and at the bottom of the dialog box it says OPEN WITH
i get this message 2 times. and have to click cancel on both to get on with what i'm doing.
Does anybody have a clue. I'v tried a registry scan nothing seems to be picked up.
Thanks in advance
Regards
Jassi
Any idea what trojan horse it was?
Try trojanremover too, it's a very good program.
Hi Jassi,
Have you checked to see if the trogan files are listed in the Start-up section of the system configuration utility...
Type msconfig into run..
the error disapears when i remove sysinfo.ocx from the start up? any ideas what this file is and if its important. Theres also another file that is on the start up called: mswinsck.ocx :s
Hi Jassi,
What are the location of these files as both of these files could be spyware, if you not do so already download and run either Spybot search and destroy or Ad-Aware both of which are free..
hi mate i have ran adaware but seems to not remove the problem, these files are both located in C:\Documents and Settings\Jassi\Start Menu\Programs\Startup
they seem to be both created yesterday. around the same time i had the virus.
Hi Jassi,
Is that a shortcut in the C:\Documents and Settings\Jassi\Start Menu\Programs\Startup..
If so are there any other files in the shortcuts target location folder.
nope thats were the actual files are there are no shortcuts. i feel like deleting them.
Sounds safe enough to me...
Once deleted I would do a full AV and spyware scan just for good measure..
yup removed the files and pc is working fine, cheers for the advise and help thanks.
