im stupid i know
DUMBO
im stupid i know
HELP!!!
How do i get hold of a recovery disk for the K415B...i havent made one :slight_frown:
10 REPLIES 10
Eugenepang
you will had to buy one, contact vaio support, its cost about 70euro
profile.country.de_DE.title
seb21__
Do you have deleted the hidden partition?
If not, I have heard if you click F10 if you can see the VAIO logo, (at system boot) then it starts the program for burning of the rec. DVDs.
HTH
DUMBO
Thank you for replying
Im completely unusure whats been deleted, some software i didnt want was uninstalled....however i think i needed it, Seb do you mean when i start the system up i should press F10? im sorry im completely computer illitrate :smileyblush:
Your help means a lot...thank you so much]
seb21__
Yes, that's what I mean.:smileyhappy:
kee-lo_
When you turn on hold F10 until a menu appears, you should then be able to make DVDs or recover Windows.
DUMBO
Ok thanks a lot, i'll give it a go
It was the shop that i bought it from that deleted the software, im in t he middle of telling then that if i cant restore, then they'll have to either buy a disc for me OR give me a new laptop...ive only bought it on Sunday :smirk:
kee-lo_
Yeah you tell them, thats terrible service messing with the computer, that should be your choice not theirs.
DUMBO
I've managed to burn a recovery disc, but unsure if that holds all the original information..does anyone know how i find that out please ?
Failing to understand why i only have 22GB, HDD C has 13.9GB with 6.25 free and HDD D has 16.2 with 16.1 free.....wheres the other 10GB ? it stated when i bought it that i had 40GB
Also ( i know its a different matter sorry) does anyone now what i use to clean the black lcd screen....
Many thanks again :slight_smile:
And im sorry to be a pain :smileyblush:
seb21__
That is the hidden partition. There are the files from the recovery DVD. You could delete this partition. But try wheter your recovery DVD works.
Make a systemrecovery only on drive C:. If it works then you could delete this partition. (you must make a complete systemrecovery).
But I would burn a Copy of the recovery DVD before.
