Impossible to find missing driver for Unknown Device in SVF1532E4E
SonyVaioUser
Hello, can anyone advise on how to find driver (Windows 10), for an unknown device in Sony Vaio laptop SVF1532E4E (or SVF153B1YM). I've tried Windows updates, Sony's website, programs like Driver Booster or Driver Update, searching it by the hardware's ID - no luck. Can anyone help?
6 REPLIES 6
The only way is by the hardware ID or knowing what is not working.
Perhaps if you share the hardware ID or a picture of the Device Manager message someone may help.
SonyVaioUser
Thanks for the reply. The hardware IDs are:
ACPI\VEN_SNY&DEV_5001
ACPI\SNY5001
*SNY5001
Everything seems to be working fine without that driver, so I can't say what it's for
SonyVaioUser
Thank you very much for the link. I tried to install it, but unfortunately it hasn't fixed it 😞
SonyVaioUser
Does anyone know how to find it? Is is possible to contact Sony to ask about it?
Pascale_F
Moderator
Hi SonyVaioUser,
You can contact Sony Support about this here.
Thanks,
Pascale_F
