cannot recover my vaio vpcee3eoe
shadow971959
having lost hdd to failure, i cannot recover my laptop using sony vaio media all i get is
1.  insert your installationion disc and restart you computer but nothing happens other than black screen
any help greatly appreciated
Hi shadow971959 and welcome.
The usual procedure is to insert the first Recovery Disc -> Turn on the Vaio -> Press the ASSIST button -> Choose 'Start from Media'
At the Vaio Care Rescue screen you can then select the 'Troubleshoot' and 'Recovery' options.
shadow971959
hi thanks for the advice/help, but that doesnt work either just getting black screen and mouse pointer
my disks may be damaged but i am not getting a message saying so, hdd checks out fine, might have to buy another set of original set up disks and try that.
