Internet Connection Unstable on Windows 8
vantapati
Hello,
I have a Sony VAIO laptop at home and recently upgraded to Windows 8.1. Nearly 5 devices (iphones+tablets+laptop) connected to Wifi box all of them are working fine but NOT the sony laptop. I used to have the same issue before upgrading it to 8.1. I see some posts online and see that issue might be resolved if upgrade it to 8.1, but its not. And also Unchecked the option 'Allow the computer to turn of this device to save the power' option in Power Management Tab in the Wifi device prorperties (as per one of the online posts) but I still have the same issue. Please can some one help me to fix this?
Vara
Nobody-in-particular
Hi Vara, Sony make several different Vaio models therefore in order to help you would need to post what model Vaio you have?
