Is it possible to upgrade the hardware ina Vaio A217S, in particularly the DVD RW, and the Radeo graphics chip...?
Gazza
Gazza,
I'm afraid it is not posible to upgrade the Radeon Chip as it is part of the computers motherboard
The DVD-RW is possible to change, but expensive (external drives are a cheaper option... ...what's wrong with it is is broke? This is a fairly recent model you have!?!)
You can upgrade the HDD, but it is a little complicated and will invalidate your warrenty. See my thread a few posts back!
Hope this helps :smileygrin:
CW
Yep, it's probably cheaper to buy a baby drive (can't remember the manufacturers name now..)
