i have a k315z with a ati mobility radeon 9200 card and i play online alot, but my fps is abou 45-65. is there anyway to increase this? possibly by allowing use of more ram?
regards marc:smileycry:
You can't use more memory, the only options available are to tweak the driver settings or try a different driver. 45-65 fps is a pretty good framerate for game playing. The refresh rate of your LCD is probably 60Hz anyway so framerates above this are just wasting resources.
thanx for that, but my next problem is of my other posting, which is the memory type issue, any chance of your having alook? regards marc
